67 190xt hydraulic pump prime
tom.b
New User
My transmission was full of water a bolt was missing so everything has water
In it my left final drive was full too so I got them all drained will I need to
Prime the hydraulic pump any help would be a appreciated.
I GOT a TIP on the hydraulic pumps on 190xt put air in the fill hole just enough to push the oil up to the pump and start it right up if it works after that you know your pump is getting weak and needs a rebuilding soon if not the pump is probably gone or sucking air with a bad seal .thanks to everyone on this sight who is so helpful.
