Where can you see the timing marks on the flywheel of a unstyled WC? On top of the bell housing thru the small oblong plate or on the bottom of bell housing by removing the large square plate?
hand start is viewed through the top, and the electric start ones through the bottom.
when you have that top plate off, look and be sure that the flywheel has no teeth, if you see teeth, it's been replaced and you'll need to view at the bottom !
