allis G losing oil pressure
cdv
my allis G starts and runs great but after 15-20 mins running loses oil pressure down to 0 using 30 wt oil in it thanks cdv
The oil pump is mounted to the rear end of the camshaft. It has to pull the oil a long way from the pan. Drop the pan and check the oil pickup screen and make sure there are no leaks in the tube.
I would check the oil pressure relief (oil pressure regulator). It's easily accessible. Just screw it out.
Could be stuck, weak or broken spring.
K-Mo
