Allis 180 PTO adjustment
Have a 180 need to adjust the PTO. Reason is when you turn off the PTO it
sounds like the hyds are on,sounds like the engine labors when off. The
manual didn't explain much as far as adjustment to it. Thanks
There isn't really an adjustment on the spool and it never changes adjustment by itself. Did you just buy this tractor??? If the PTO lever is going full stroke and the PTO starts and stops like it should, I don't think you have any issue, even tho you think you do.
