D 17 series 1 rear wheel bearings
Paul V B
Anyone have the Timkin bearing numbers for the final drive bearings? The part numbers on Yesterdays Tractor site does not match Agco part number. Agco parts book doesn't really get specific for series 1 2 or 3. Both mine definately need to be replaced. I did Google the Timkin cup part number from YT and a matching bearing number comes up on one site. Is there only one Timkin bearing going to fit a particular cup?
For the outer bearing Agco shows 70229110 and Y T has 70057006 so there are two different Timken numbers. Not sure which is the correct one. Neither site is specific about serial numbers.
they may be the same, IDK.
On the YT page they talk about finding the correct part for the D17. see link
I'd ask them whether that is the same; and if not could they provide the correct p/n
Might want to take a pic to send if need be.
70057006
I couldn't just pull the hub out . Read the outer bearing was prob slightly pressed onto the axle so I rigged up this bottle jack to press the axle out. Didn't take much effort. There is only a tiny lip to try and hit the old race out so I'll probably use a grinder and grind the old outer race off. I punched the inner race out with no problem.
