WD hydraulic pump leak
isuvinny
My WD is leaking quite a bit of hydraulic oil. I can't really see where its coming from, but the puddle is right under the pump. Is there a seal, or gasket there that needs to be replaced? Any suggestions? Thanks
Clean the whole area up and then add some dye-lite to the oil. O'Reilly's part number TP-3090. It is a dye you put in oil that shows where the oil is leaking at. I have used it in power steering systems and other such systems. Works real well and pin points just where the leak is if you have the area cleaned off first
