WD 45 starting
RPatrick
New User
WD 45 would start with starter doing some humming so took starter off and had it rebuilt. Put starter back on. Does a great job of turning over engine, but tractor does not seem to have any fire. Has plenty of gas. What else should I check that would cause it to go from starting before the starter was rebuilt to not starting at all now?
First check to make sure that there is fire to the spark plugs, if not then clean or replace points, could also be bad coil, bad key switch, or no power to the coil. A test light is a good use full tool to have.
Did you put ALL the wires back where they should be when you put the starter back on???????? One easy way to do some simple trouble shooting is to run a hot wire from the ignition side of the battery to the ignition side of the coil and try top start it. If it starts go back and check your wiring at the starter you may have left the ignition wire off. If all wires are on how long did it take to get it rebuilt the points may nee to be cleaned
