Mike in MI
Question: I have a Case 530 I believe it"s a 1966. Question I have is I"m loosing Hydraulic Oil from the hydraulic resesvor into the rear end. It"s not a fast leak but checking the hydraulic on the dipstick it"s down about a quart or less in a months time depending how much I run the tractor. Anyways the rear end checks over full bye a 1/2 inch on the stick. Enough where the oil seal on the RH side brake leaking.
I"m guessing on this but is it possible the (3 pt piston) under the seat possibly leaking oil into the rear end? Or is there another proviable place it could be coming from?
I never had the top off the 3 pt unit, but is this something i might be getting into that way----over my head so to speak? Is the a way it can be checked before tearing into it?
Thanks! Mike
Thanks! Mike
