My 1953 Case SC hasn't had a transmission gear oil change since I got it 2 years ago. (Haven't run it much either) So with this hot weather, I figure it's a good time to do it. I've read some of the, "search," hits here which helped. I think I'll pull the drain plugs, (2), and drain most of it into containers. Then let it sit, still draining, for at least 2 days. I know the color of the old oil is a bit tan looking, so that's a bit of moisture through the years. No sign of water. Main question here tonight is: Should I flush trans case with anything? I thought about putting in a gallon of kerosene or something, letting it sit overnight, then re-draining for a day. My concern is if some of the kerosene gets trapped in any cavity and causes a problem later. So how do all of you handle this? Flush - no flush? With the price of 80/90 weight gear oil, I'd like to do it right the first time.
Dennis in E WA state
