who is on their toes?
chuck machinist
I found a post in the archives that was worth another looksee! Who and what happened to this old girl? Rjones093 was the original poster a number of years back . Bone apa teat! CM
Bingo!. I enjoy hitting the Archives from time to time, and found this old girl . You would be wearing Earplugs you think!CM
There are a couple of those screamin-oil dripping LAs around here along with a L. There was a conversion kit that could be bought to make the conversion.
If I was doing one, I would put a 671 in, and stretch the hood, steering arm, and wishbone.
Loren
Chuck, Here is a video I shot several years ago of a old Case Detroit out plowing. I don't agree with his clutch abuse but I did like seeing it go.
<iframe width="560" height="315" src="https://www.youtube.com/embed/AqBH-8OughQ" frameborder="0" gesture="media" allowfullscreen></iframe>
(quoted from post at 16:35:04 11/21/17) Chuck, Here is a video I shot several years ago of a old Case Detroit out plowing. I don't agree with his clutch abuse but I did like seeing it go.
&lt;iframe width="560" height="315" src="https://www.youtube.com/embed/AqBH-8OughQ" frameborder="0" gesture="media" allowfullscreen&gt;&lt;/iframe&gt;
What was that fool trying to do, pull the plow in road gear? A LA should pull a four bottom plow with the original stock engine. The LA in the video could have done it in a lower gear.
This is like, all talk and no action, what a mess they left the field in, man if I owned this, I would pull the jimmy out and put the "LA" motor back in geez.
Years back I had a semi, a Ford ( we called it a 2 story falcon) and it had a jimmy in it, man, it was a happy day when I replaced it with a 350 Cummins, in a Chevy Titan, (a ok truck in its day)
(quoted from post at 23:54:47 11/21/17) This is like, all talk and no action, what a mess they left the field in, man if I owned this, I would pull the jimmy out and put the "LA" motor back in geez.
The jimmy diesel needed to run above 1800 to have any power. 2000 to 2400 was even better. When operating a truck with a jimmy diesel you had to slam you fingers in the door, then drive it like you were mad at it.
That is how you drive a gmc diesel in a truck. Keep them wound up all the time. We had one in a worthing air compressor for running multiple jack hammers and such. We put in ear plugs and muffs over the plugs. At the end of the day your ears still rang.
