Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Case IH 585 steering
addibeck
02-12-2018 14:52:46
I have a Case IH 585 that broke the hydraulic fitting in the steering cylinder shaft end when turning left. I replaced the fitting and it would barely turn left at all and broke the fitting again when it bottomed out. I replaced it again and will will not turn left at all. It turns full right good but wont turn back left. When you turn the steering wheel left the steering cylinder shaft extends and will break the fitting if you turn it too far, but the wheels don't turn left.
Anybody know whats going on?
Bruce from Can.
02-13-2018 03:27:01
 Re: Case IH 585 steering in reply to addibeck, 02-12-2018 14:52:46
Have you tried asking your question on the IH board? This tractor is a Doncaster, English built IH, and not a real Case tractor. Might find more answers from IH guys than Case guys.
1175scott
02-12-2018 16:54:30
Is it a 2 wheel drive? Are both ends of the cylinder rod sticking out the same amount? This would be when the front wheels are straight.
addibeck
02-12-2018 20:45:38
 Re: Case IH 585 steering in reply to 1175scott, 02-12-2018 16:54:30
It is 2 wheel drive and yes both sides are sticking out and it is turned full right. I'm sure this is not normal. I thought I might loosen the fitting so fluid could escape and manually force the cylinder back all the way. (left side) I also wondered if air could be trapped in one side of the cylinder and how to bleed it off.
1175scott
02-13-2018 03:37:49
 Re: Case IH 585 steering in reply to addibeck, 02-12-2018 20:45:38
The piston which is pressed onto the cylinder rod has moved. The cylinder will have to be taken apart. Then you will have to press the piston back to center on the rod. This will have to be done in a hydraulic press. Good luck! Sometimes a new rod is required.
addibeck
02-13-2018 08:27:34
 Re: Case IH 585 steering in reply to 1175scott, 02-13-2018 03:37:49
Thanks Scott, I'll pull it off and see what I can do. I think I will post on the IH board as Bruce from Can. suggested too.
Appreciate all your input.
