My David Brown 880A was leaking antifreeze while cutting grass so I parked and shut it off. As soon as the engine stopped about 1 1/2 gallons of antifreeze poured out. I have since refilled the radiator and started it up and nothing leaks. I assume the sudden loss of fluid was out the overflow hose. While running the water pump does not squeal and the radiator and hoses heat up, so I assume there is water circulation through the pump. Can I assume the thermostat and water pump are working properly?
Any help would be appreciated. Thank you. BJS
