I have a VAC that after about 10 to 15 minutes of use the temperature gauge reads close to 200 and continues to climb. There is plenty of coolant, there is not thermostat on the tractor and the fan runs fine. When I shut it down the water in the radiator is real hot.
What should I check as to why the water heats up so fast?? I would appreciate any help as I am at a lost. I should mention I switched out the temperature gauge and probe in thinking it was misreading but the old one and the new one show the same thing.
Thanks you in advance
