My VAC started leaking oil into the brakes. It has single disc brakes. I have the left side off currently, and will do the right side after the left side is done. When putting the bearing carrier back on, should there be any kind of sealant between it and the casting? There were 7 shims on it and when I put it back on I'll check the shaft endplay and remove shims if needed.
I soaked the brake disc in gasoline for about three days and it is now drying out. Any other suggestions for getting the oil out of them? There appears to be about 1/16 to 1/8 of an inch of pad above the rivets, how does that compare to new pads?
The serial number is 5550713. How do I find out what year it is and whether it is a VAC or a VAC-13?
