831c engine
madkor
I have two case 831c tractors and I want to swap engines. one is an 1961 and the other an 1964. Both are diesel. The question I have is are the engines the same so I can swap them.
Thanks
(reply to post at 18:53:13 09/17/18)
think the 1961 would not have balancer and the 64 would. Someone here probably can provide more details on that. I am sure that the motors will interchange.
Pretty sure they both have balanced cranks. Only
59 and early 60 models with single shift lever don't
have balanced cranks from what I have worked on
(reply to post at 12:14:35 09/18/18) [/q
thanks! I have an 830 single stick that doesn't have a balancer. I believe the block has been replaced it is drilled for a balancer and doesn't have a serial number. I also have a two stick and they seem different at full rpm.
