Case 580D hyd. fluid
I had a big cyc on the Hoe leaking real bad out the top. It has set about 608 weeks, and I now have milky Hyd. fluid. I had the cyc rebuilt and was not there when he came to do it, however, he said I need to change the hyd. fluid and filter. This is a borrowed hoe and wondering how many gallons it hold and where the drain plug and or plugs is at. Any help, so I can get it serviced and returned. Thank you.
Hyd. refill is 12.5 gal with filter change 12 gal. without.
There is a plug at the bottom of the Hyd. tank on the right side
Of the machine.
Spin-on filter under the hood on the right side also.
Tom
