case 115 battery ??
mb58
Is the 24 volt system on a Case 1150 dozer (about 1965 mod) supposed to be positive ground or negative?
Are all 24 volt systems positive ground?
The 1150 was 24V negative ground,original had 4 6V batteries connected in series,if you need to polarize the generator momentarily tip a jumper wire between the Bat and ARM terminal on the regulator.
AJ
