Caterpillar 933 11A
Joker123
New User
Hi everyone one , am in need of some help! The track came off my cat. After I put it back on . That side don't want to drive any more. Also the brake doesn't work any more on that side. I think some thing is broken from the brake down to the final drive. But where do I start looking?
Maybe one of your guys can point me in the right direction.
You could check the brake linkage and removed the small cover for the adjustement brake and maybe the pinion spleene are stripp or bevelgear shaft stripp in stering cluch drum
Either the spline has sheared in the brake drum or the final drive has stripped some teeth,drain the oil from the final drive housing and check it for metal.
AJ
Hi guys
I have taking the final drive apart and found a broken Pinon shaft(part #2F1175 )
Any of you guys would know where I can find a used Pinon shaft?
Thanks
