Got a Case 850D dozer. Has a 6 way blade.
Hydraulics spool for blade has a leak. Took the
spools to a hydraulic shop and they put new o rings
in it.
Put it back on the dozer. Still have a leak. It is on
the tilt control of the of the blade. It is a drip out of
the bottom of the valve that works the tilt. Does not
leak if you are not moving the lever to change the
tilt on the blade. When you move the lever to
change the tilt it drips out of the valve that controls
the tilt.
Don't know if I have used the correct terminology
describing my problem.
Thanks in advance.
in it.
the tilt.
Thanks in advance.
