Gearmatic Winch - Information Needed
TallGuy123
New User
I am doing some restoration work on a 1966 John Deere 1010C diesel that has a Gearmatic winch. The nameplate on top of the unit is mostly useless as I can read very little of it. The left side plate has "C 713 A" inscribed in the casting....not sure if that's a part number or the model number to be honest. It has been working...sort of...at least until brake fluid from the clutch area of the winch started pooring out on the right side. I need an exploded parts diagram with part numbers and a source on parts if that exists. Any applicable leads would be greatly appreciated. I've worn out Google with searches!! Thanks for your time!
I would guess that year and size a gearmatic #9 winch. Clutch is internal expanding with a slave cylinder. Brake line for clutch goes in center of end cover and has a seal that can leak if the cylinder itself is not the culprit. Brake in a contracting band also with a slave cylinder that can leak. Brake band has an adjuster on the bottom of the winch IIRC. Goggle gearmatic 9 winch diagram and you may have better luck.
