Help with Allis HD 6G crawler
Richard G.
Young friend needs the U joint coupling that goes between the clutch and transmission on a 1969 HD 6G loader crawler.
Anyone know of a place to find one?
Thanks,
Richard in NW SC
I got all mine from NAPA, sure a lot cheaper than the dealers. I just took the old 1 with me and they kept my number in the system. Whenever I needed a new 1 they knew what I needed.
The number on the spider is EX15.
He needs 2 spiders and caps.
The AC part # of the spider assembly only is 70086284,it interchanges to NAPA # UJSUJ540,you need two of them the spec says they are made by SKF one of the best.
AJ
Not Allis but some U-joint links here
https://www.redpowermagazine.com/forums/topic/115117-dresser-td7e-universal-joint-help/
Yes the caps are part of the assembly,the also come with the bolts and grease nipples.
AJ
Thanks AJ. I just called the young fellow and he was in town. He is gonna go by NAPA and talk to them.
Our NAPA folks are good and some of the guys have been there for nearly 40 years.
Richard
If you have any trouble in case the numbers I quoted are wrong for your machine just do as one of the other guys suggested and take the old U/J to them and they are sure to have a match.
AJ
