2010 hyd, spool valve
trak
2010 with jaw bucket, the bucket tilt/forward valve has gone dysfunctional, it works good to pull the bucket up(cyclinders in) but forward is just a gravity game.. is it possible that their is a overload tripped and stuck? Like when you are lifting too much with the bucket? I've also heard that the spool is worn out, idk.. need a new valve or this one fixed, real soon, I offered to do some work with it... thx. I don't see much of anyway to cheat it... its a three spool valve, the center valve is the one jacked up. thx
This is a JD2010 with a 4 in 1 bucket that won't tip the bucket forward to empty it but will crowd it back,the most likely cause is the port valve for that movement,if the lever feels normal and moving the valve the right amount it could be the port valve for the dump is stuck open or an o'ring on the body has blown,there is a port valve for each movement of the dump and boom cylinders and the main regulator valve as well,the dump valve and crowd valve are set different,if the parts drawing uploads the valve has red line around it,take it out and see there is nothing holding it open or the o'ring is blown on the body.
AJ
