Bfinney5238
Guys Im hoping to find someone knowledgeable on the 350b. I was getting a grinding noise on my left final
drive. When I was pulling it back it would grind. So I though it was worn clutches. Pulled the drive off
replaced the clutches and put it all back together. Didnt replace the pressure plate I had good used clutch
discs. When i adjusted the lever that you push against the throw out bearing I cant feel the throw out
bearing. I have adjusted it all the way out. I couldnt feel it before hand either. The part where you stick a
crowbar in the housing and move to the throw out against the pressure plate. I decided to adjust it back to
the middle without trying to feel the where the bearing is. And now no grinding.. is that a symptom of a
worn pressure plate?
