JCB 3cx neutral start switch
ppp.m.
New User
I have a 1986 Jcb 3cx. I need to replace the neutral start switch, have checked all other area"s..battery, lever etc. <br>Just wondering if anyone can tell me where this switch is located on the machine, thanks..:)
If your 3CX has a cable F/R shuttle shift you have a Borg Warner shuttle like the one above,the neutral start switch is located on the R/H end of shuttle valve,put a second person in the seat to operate the F/R lever,you will see it move the arm near left back of the unit,the switch is opposite it on the right side,it screws into a triangler plate held on with three bolts,if you have a syncro shift machine the F/R shift is electric and the F/R switch itself has the neutral start switch incorporated with it,the unit has to be relpaced,check all the connections esp the multiplugs in case of bad connections.
AJ
thanks a mill..:) its great to great good advice from someone without been charged for it, thanks again..:)
