Charlie ZUthke
I have been trying to make an old dozer run again. This dozer was blowing bubbles into the radiator. I removed the cylinder heads earlier this summer and found a fire ring was leaking. I removed the cylinder sleeve from that cylinder and shimed the height of the sleeve up where it is suppose to be matching the rest of the sleeves.
As I'm putting things back together I have can not fine one of those thin sealing washers for the injectors and precups. Does anybody have an idea where I can get a couple of these sealing rings? I also have one that is broke. Thanks much Charlie
