c-248 engine rebuild, wrist pin bushing clearance
Cannot find the bushing to wrist pin clearance for the c-248 engine. Fairly certain it is less than the 0.013 gap I now have. Thanks, Jim.
Thanks for the replies. I have new bushings coming. the engine has new pistons. pins and sleeves, but the rod inserts were not changed. Not sure why bushings were not fitted to the new pins. This engine was stuck from rainwater down the stack. Machine is a T6 crawler.
I have the IHC gas engine repair manual but several key parts clearances are not covered. This engine has the smaller diameter rod journals which I believe makes it a earlier model. I appreciate the help. Jim.
So I received my replacement bushings and they are paper thin, 0.056 total thickness. And they are out of round by 0.022. ID varies from 1.318 to 1.296. Will this even out when driven into rod. Doesn't have much meat for reaming to size for the pin. Jim.
