dcpky
Hey guys looking at a B414 gas engine wondering if the muffler under tractor can be changed to vertical I see on this site I can buy a manafold for diseal vertical what are my options
(quoted from post at 00:21:14 09/19/17) Hey guys looking at a B414 gas engine wondering if the muffler under tractor can be changed to vertical I see on this site I can buy a manafold for diseal vertical what are my options
If you check the CIH parts diagram you will see the upright muffler for the B414 gas is strictly a pipe with a 180 degree bend and exits on the left side of the tractor about two inches outside the hood. If you are handy you can make your own pipe from muffler tubing available at muffler shops. Check Messicks site to see exactly what I am describing. Similarly a good muffler shop can recreate your under slung exhaust pipe if you have the original as a template to use. The muffler is the same as the diesel one and is still available.
