Had to get a new er top for the carb. Got it back from the mechanic today. Ive had it on and off 3 times now. It dosnt run right. It dosnt idle, and it DOES race. Im 70, and ive forgotten which screws do what, other then the idle adjustment screw, which comes out from the top straight outward. Ive adjusted it in and out to no good response. Which way idles the engine down, going in or going out? Which what do the other 2 screws do. I know one is air and one is fuel. Im assuming the one set at an angle at the bottom is air, and the one set near the butterfly is fuel. Am I right?
What is a good starting setting for air and gas. 3/ 3 1/2 turns from inside out?
