986 remote valve weak pressure.
Thad
I've got a 986 that one remote has 2100lbs or more but the other one only has 1550. I assume it's bypassing in the valve. Anyone had this trouble and how did you correct the priblem?
Is this an early one or late one and early is open and late is closed center on close there screens Orvis mite need cleaning and you take them off the out side is the motor valve if is closed center make flow control wide open
