Farmall M 3 point hitch
SgtMoe
I am looking to build a 3 point hitch for my M similar to this and I am looking for some opinions as to what thickness of metal to use for the uprights. Would 3/8" be thick enough or should I go with 1/2"?
3" x3" x 1/2" angle.3/8 is probably adequet,but 1/2 is better.2" round for the rock shaft if using a single cylinder(3 1/2 or 4"). 3/4x 2 or 2 1/2 for the tug links.Standard category one top links for the lift links. I recommend using the 'convertable' balls. Cat one one one set of holes.Roll it half and there is cat 2 holes.use cat 2 top link.
I thought the same however the e-mail no longer works and the phone number has been disconnected.
This looks identical to the Saginaw 3pt on my M, dual Maxim cylinders hook up to the belly pump.
https://external_link/3_Point_conversion_kit_Farmall_H_M_300_350_400_450/p26826
