Farmall H - Nose bolts & spacers
Does anyone know the thread and bolt size for the mounting holes in the nose of an H? I suspect the M is same size.
If you know the spacer size that would be great too.
Thank you.
1/2x 13(coarse thread) about 1 1/2 or 2" long. I used 1/2" black pipe as a spacer cut 3/4" long.Your acctuall use/'mileage' may vary,depending if or if not you actually attach something to those bolts.
(quoted from post at 23:17:56 05/25/18) 1/2x 13(coarse thread) about 1 1/2 or 2" long. I used 1/2" black pipe as a spacer cut 3/4" long.Your acctuall use/'mileage' may vary,depending if or if not you actually attach something to those bolts.
I'll be trying to mount a McCormick 30 end loader. The tractor it came off was missing the bolts but the book says it should have them.
