Re: Super C clutch won’t disengage
keeter84
05-25-2018 14:23:05
So looking in I could see one of the fingers was away from the pressure plate. I tightened the bolt up on the finger and it’s back working. I’m pushed for time and just hand tightened. Seems weird to me though.
old
05-25-2018 14:35:24
 Re: Super C clutch won’t disengage in reply to keeter84, 05-25-2018 14:23:05
Sounds like you may have lost a lock nut. On most that I have seen on any pressure plate the adjustment parts have a lock nut on them. Lock nut comes off and then the finger gets out of adjustment and then that area of the clutch does not release and cause that
keeter84
05-25-2018 17:04:14
 Re: Super C clutch won’t disengage in reply to old, 05-25-2018 14:35:24
On the back side ?
CharlesTX
05-26-2018 07:14:22
 Re: Super C clutch won’t disengage in reply to keeter84, 05-25-2018 17:04:14
The lock nut is under the adjuster bolt head. Look at the other fingers to see where they are adjusted to use as a guide, you will need the lock nut to keep the adjustment.
