follow up 560D oil cooler leak
Hayfarmer
Finally got around to fixing leak. As Pete23 suggested pulled LH side frame off. Couldn't find gasket for manifold to engine block so used silicone gasket maker. Easy job to fix leak, 2 new O rings but quite a job removing and replacing side frame. The 2 bolts for wide front are not easy to get to on that side. Doesn't leak anymore. thanks for the help
The one I recently did,I only loosened the left frame rail enough to remove the cooler.I removed the rear bolts but only loosened the fronts. The o rings on this one were hard as any I had ever seen.Mark.
someone said you dould do it without removing frame rail but I couldn't figure out how to get in there without. I blocked up under bell housing to take pressue off rail. Motor mount bolt and 2 front end bolts especially back one were challenging. My o rings were pretty hard too
