Re: Super C clutch won?t disengage
keeter84
Yep it was working fine and I have been using it regularly
lately. Was at the end of the row and depressed the pedal and
it wouldn?t disengage.
You can check to see if a finger pin has come loose by removing the bottom
access plate. It is possible to reinstall the finger/pin through the
access plate but it is a tight space.
So looking in I could see one of the fingers was away from the pressure plate. I tightened the bolt up on the finger and it?s back working. I?m pushed for time and just hand tightened. Seems weird to me though.
Problem came right back before I got out of the shed. I got the wrenches out and the bolt feels stripped ?? Of course the hole is small so I can?t see it well and I ve never examined a clutch closely to really know about it. So if the bolt is ?feeling stripped? then what do we think is the problem ? Thanks
