Sediment bowl gasket cross reference
I need a 2" sediment bowl gasket, IH part number is A11208. Local NAPA store says they can't cross that number.Is there a comparable gasket that I can use?
I done a quick search and got these napa part numbers
IH 360679R1 Fuel Sediment Bowl Gasket NAPA 730-9506
IH 49923D Fuel Sediment Bowl Screen NAPA 730-2373
NAPA take your bowl along so you get the rite size mine came with screen and rubber gasket. Check your main assy to make sure it isnt warped cause if it is you need to replace it easy to check just put the bowl in and see if it "rocks'
O'Reilly's part number for the fuel strainer gasket is #398. I keep a few on hand and have 2 sitting here on my desk
some of those parts people are so useless. i buy my gaskets at peavy mart in a package of about 20 gaskets for around 20.00. anytime i need a gasket i have lots on hand.
Yes Gene, a warped assembly is very common. Also, tighter isn't always better. That's how they get warped.
I don't know what NAPA sells now, but I quit buying their black rubber gaskets. The black gaskets don't tolerate much imperfection in the mating surfaces.
I use only the rubberized cork. The softer material can seal minor warpage.
Hate to say, but Deere has bowl gaskets made of cork
yet. Believe they were $1.65 or thereabouts. They
are thick enough to take up the minor differences
on the base.
O'reillys local didn't know what I was talking about,
& couldn't find #398 on their computer.
Absolutely useless.
Jim
