504 Transmission, Clutch issues?
My 504 diesel quit moving the other day after doing some plowing. I had just finished and went to go back to the barn and it stopped. Engine runs fine, pto runs fine, hydraulics are good, it just won't move. The day before i had ran it in most every gear, hi/lo without issue.
Won't move how?
Won't move as in you let the clutch out and nothing happens?
Won't move as in you let the clutch out and the engine bogs down dies?
Sudden failures like that are most likely either the spring damper assembly in the clutch disk or the splined coupler in front of the TA clutch. If you take the stamped steel cover off (four bolts) on the top center of the clutch housing you should be able to see the coupler.
