I have a hook-up for a 2-way cylinder on the back of a Super MTA, so it is a hook up for 2 hoses, an in and an out. I am looking at an older round baler that has a hydraulic tie, so dual hook-ups are needed, one for the baler lift gate and one set for the hydraulic tie.
Is there a way to put in a valve with 2 hook-ups and a toggle valve to switch between 2 remotes in order to run both the gate and tie separately? I would not need to run each simultaneously as you first tie, then unload. Thanks for any input.
