F12 problem
James Williams
I just finished a F12,Rebuilt motor and head,carb has been cleaned thoroughly,The tractor starts and runs pertty well,but when I put it in 1st gear it wont move out of its tracks,The motor justs dies,Im leaning toward the timming,I would like other opinions
jimmy
Does it feel like it's trying to put power to the wheels and then lugs down and quits?
Wondering if maybe you have a tranmission issue, stuck in two gears or something.
Jimmy, Your brakes have not rusted stuck?
Has them stick on me once. would not move at all. If all is fine I would check the timming like you said. oldiron29
The trany is fine and its trying to put power to the wheels,Im going to play with the timing when I get a chance
jimmy
Got to go with oldiron29, jack up the rear end and see if the wheel brakes haven't rusted stuck, also can check on trans stuck in two gears.
