S/C BOB
I`m trying to get my Cub running up again after restoration. When I put the wire on the starter post from the amp gauge it`s the 4 th. of July a little early...Anyway it does have a lot of fire on it.I wired it up like it showes on this forum any suggestions, any help appreciated..
Bobby
Bob, go to the following website, scroll down the page untill you find the section on Cubs. Then detremine which wiring diagram ya need. There is some really good info here..HTH
Keith & Shawn(Special Olympic Gold)
IH Wiring diagrams
Gotta be either it's wired up wrong or the cutout relay in the voltage regulator has stuck closed.
First double and triple check your wiring - make sure all the connections are made to the proper terminals. Also make sure there are no accidental grounds. Pay particular attention to the wire between the voltage regulator BAT terminal and the ammeter. (Also if your Cub has lights check the supply wire to the light switch....)
If you find no errors or grounds, next temporarily disconnect the wire from the GEN terminal at the regulator. Now try reconnecting the wire at the ammeter. If you still get fireworks the problem is a bad voltage regulator - time for new one.
