I have a 544 international with the 239d and i can"t keep it running........when u start it, it runs fine for about 20 to 30min,then the engine will speed up and slow down it"ll do this a few times then stop....just like u turned the key off,i replaced the filters and bled them and at the injectors and the fuel just trickles out when i loosen them(shouldn"t be under alot of pressure when the engine is turned over?)I"m thinking injector pump bad and if this sounds like a bad pump where can i get a replacement or have this one rebuilt?And it"s never had much power.I thought it was water in the fuel,so i tested it and it shows none.
