'42 farmall H
Anonymous-0
Ignition problem-I think? I ran out of gas and left switch on. week later, filled with gas but now won't start. looked and smelled like electrical burn. replaced points, condenser, switch. (previously converted to 12 v). turns over but still will not start. any thoughts???
You might have burned out the coil, never leave the switch on when the engine is not running, it will also drain the battery if the switch is on and the engine is off.
ok; added resistor, new switch, distributor cap, condensor, points, and coil. Also, changed fuel filter. still turns over but does not start. any other thoughts?
could in relate to the solenoid? don"t even know what that is for...
