Wheel Weights for IH 340 Uility
LeRoy D
New User
I have a International 340 Utility and would like to know which rear wheel weights will fit that tractor model tractor
The parts manual shows the split type wheel weights. They have the same bolt pattern as the one piece so I would think that any of the wheel weights for a C on up through the 66 series would work. They may not pass muster with the correctness police but if all that you are after is ballast then any of them should fit.
My 340U has 24's with 14.9-24 tires. I have the 2 piece cast iron weights for the 24" wheels, but they only add about 250 lbs. I had the tires filled (calcium chloride), which added about 1000 lbs. At just under $200 for the fill (and NO work on my part), I think filling the tires was much more cost effective.
I don't know how much the weights cost, as they came with the tractor. I am only assuming they would cost more per pound than the liquid ballast.
