Schwarts wide front end info.
I've got a Schwarts wide front on my '52 Super M and was wondering where i could possible get a manual for it. Inspection of the wheel bearings show that they were jerry-rigged to prevent the wheels from "tapering" inwards too much. Any Help is much appreciated.
-David Goode Coggon, IA
New parts are readily available, but I don't know if there is a manual. I'm not quite following you on the "jerry-rigged" bearings.
The nut was allready at the end of the threads, yet there was still "wobble" in the hub preventing proper alignment. The previous owner added three more washers to try to fix it. What I think I need is a Outer Grease Retaning seal and a new washer.
Sounds like either someone installed the wrong bearings, or the races are worn out. If it was mine, I would be getting a wheel bearing kit.
