Tractor Carbs
Did anyone get to the Best Show On Tracks Woodland CA? I was going to go but could not handle the 106 deg heat with the pills the doc's got me on, how did it go and will it be back next year? Also I kept getting wimp wood, 3 of the pitman sticks I got would just fall apart or the bolts loosen up after 3-4 hrs of mowing even checking before and after each day. So I got a Ford stick that was much heavier but a 1/2" shorter. Now I have 0 problems except it just wont cut well on fine grass. Is there a quick simple way of checking or setting timing? I know I need to get the proper length stick but don"t see where to adjust or set timing? Someone please help, it"s so dry I can"t use any rotor type mower! And since most of the state is on fire I can"t hardly see today with all the smoke and don"t want to make any more!
