farmall h and m rearend fluid
What type of oil should i run in the rear end/transmission of the farmall h and m i have? Do i run straight 30 wt. ????? We haven't changed it for a while ..... some drips out the pto shaft on them when they are hooked onto a auger.
Use 90 weight gear lube or 85-140 gear lube.
there are 2 drains on the H & M; large one at the rear and a small one just back of the clutch housing.
