10-20 HEAD GASKET
JDMAN60
I"m back I posted a couple weeks ago about a 10-20 that I saved from the scrap man. I tore the engine down today and found that someone had improperly shimmed the rod bearings and had #2 to tight and #3 way to loose after some some shim swapping the engine is no longer stuck. Now I am in need of a head gasket,water manifold gasket and a valve cover gasket. Does anyone know of a supplier for these? Thanks in advance for you help I want to hear this old girl run again soon.
