IH loader from a IH350 will fit IH544?
Anonymous-0
Will a loader that came off an IHC350 fit a IHC 544? Seller has one for sale for $500. I believe I can make this fit, but don't know. Also, what valveing would I need to make this work. I have a one spool valve now. Thanks for looking, Bob.
If you are expecting a bolt-on fit, the answer is MAYBE.
If you are willing to torch and weld, the answer is YES.
Which "IHC 350" and which "IHC 544" are we talking about? IHC made two versions of each tractor.
If both tractors are Farmall versions, then the loader should bolt right on.
If either, or both, tractors are Utility/International versions, then you will probably have to do some cutting and welding.
Do you know the make and model of the loader?
Thanks, I purchased the loader attachment for $500. I will have to modify the lower support arms that extend to the axle. Do you know where I can get cylinder repair kits? ID plate says:
Du-Al Mfg Co. (now Woods?)
Sioux Falls S. Dakota
D73-7348
Bucket 1273
Thanks for your help, Bob
