Tom Fleming
the parts manual calls for oil guage 18113 DA. i have a 31041-DB which appears to be for an F-12/F-14. are the pressure ranges the same? Where should I expect the needle to be if I am running ok. Right now, running straight SAE HD 30, it is about 1/3 of the total movement, and pointing at the "o" in oil, which puts it about 10 o'clock on the dial. I also notice it takes a minute or two for it to pressure up and start reading.
I have no nocks or noises coming from the lower end, and all the connecting rod shims are still installed.
soooo, $25 question is, is the pressure ok.
