Farmall B engine
Mark76
New User
Trying to overhaul a farmall b engine. The block has a casting number of 354898R2 and the head is 6716Db. Trying to figure out what I exactly have for an engine. I have tried two kits from TISCO a EOK1159-LCB and a EOK1150-LCB. Neither worked. Don"t know if this an original engine or not. The tractor serial number is 92295. I have a crank number of 356308r1 and a rod number of 30926. Long story short is that I do not have the original pistons. I do have original sleeves.
I think you have the Super C C123cid engine. Your pistons should be 3.125" in diameter and the sleeves should be 7.060" in length. You can put an overbore kit without any machining with 3.250" pistons to raise the cid to 133ci. Hal
Does your tractor have a water pump? Most B's do not. That would indicate if you have a replacement engine. Dave
the original sleeves measure 3.00 id and the overall length of the sleeve measures 6 and 7/8" .
