Belly pump on H
Pairodox
I've noticed that my belly pump is leaking. From the bottom if you look at the thing while on your back ... and from the 'front' if you look at the thing from the observation port. Are there gaskets that need to be replaced here? I'm guessing I need to remove the entire pump. Is that hard? If I disconnect the hydraulic drive shaft and (3) supply lines do I then simply remove the bolts on the bottom? Can't be that simple.
Floor Jack really helps, some use threaded rods to lower it down, but that would seem to take forever.
Look in archives, thousands of posts regarding this subject.
Gene
not a bad job to do , VEERRY HEAVY!!!!!!!
use a floor jack and blocks and an extra set of hands to help guide it down and back up
I just pulled the belly pump out of my M. I used the threaded rod trick. it worked fine, but it was slow. If I do it again, I will still use the threaded rod for stability, then just put some blocks under it while taking out the last two bolts, then pull the blocks, and lower it by hand, it was heavy, but not so bad I wouldn't feel comfortable lowering it by hand. Your results may vary.
Ben
